If you build it, It will Run!
Posted: Thu Jul 03, 2008 1:54 am
by speedracerles
Im trying to build the ultamite Isuzu Impulse, Im looking for help with what parts to get that would give me the most power,plus Rep for all of those isuzu that dont get any Love out here.... any thing would help major or minor what ever is cool...
Turbos: , Headers, brakes, intake system, ect....
Posted: Fri Jul 04, 2008 10:25 am
by speedracerles
I know that there is someone out there that know something.
Posted: Sat Jul 05, 2008 9:39 pm
So what other posts, forums and info do you have?
What is wrong with their suggestions?
Or - what performance are you after? Torque? Horsepower?
Or how many heads to spend? Or $ if you prefer?
Try to make it easier for us to answer.
Only kewl dudes drive kewl cars.
But if ya wanna win, we too think that's kewl.
But only the coolest win.
Posted: Sun Jul 06, 2008 2:27 am
by Virtual-R
4ZE1 Twin Turbo
Building one of those engines at work currently, will be running a single TD0620G, full LPG Gas research setup, electronically programmable ignition maps, ground up rebuild with brand new head being ported, stronger valves custom grind cam and racing valve springs.
Should be a pretty tough engine once its done, even as standard they are fairly impressive, huge amount of low end torque, compression is fairly low on them which makes them well suited for turbo applications.
I reckon a couple of smaller turbos on a 4ZE1 would be a good little machine, not lacking torque so they will boost fairly easily, not to mention the size of the engine, sharing 2 cylinders per turbo there's 1.3 litres capacity.
Posted: Mon Jul 07, 2008 1:29 pm
by speedracerles
Im looking for all the above, my friend... Hands down! I would say just start throwing things out there im pretty sure things will peace them selfs together right? I mean I do have two of them to play with... I just want them to be cooler then they already are you know! So fill free to give me your input ok... thanks...
Posted: Sat Aug 23, 2008 1:07 am
by speedracerles
The t-bird coupe turbo
Could I just bolt this up, or do I need something done before I can put it all the way in? I need help...
Im also trying to lower my car, the 86 piazza. it handels sloppy right now so..hit me up and let me know what I need to do. thanks
Posted: Sat Aug 23, 2008 5:42 pm
by Madcat
The T-bird turbo has a different bolt pattern than the IHI.
http://www.well.com/~mosk/AdapterDimensions.html
but the dimensions for the IHI holes (countersunk) are off.
My manifolds measure 2 1/4 not 2 3/4.
My T-birds dimensions match perfectly.
Also if you use the entire t-bird unit you need to re-clock the exhaust housing to keep the oil drain pointing down.
BUT you can take the intake housing and wheel from an '87-'88 turbo and bolt it directly onto the IHI unit. you CANNOT do this with an '86 or older B/C they use a garret turbo for those years.
Don't have any ideas for the suspension.
Jim
Posted: Mon Aug 25, 2008 4:37 pm
Stick to the Marque!
Isuzu 4200R V8, or the Hummer turbo diesel (7.6L?).
Posted: Tue Aug 26, 2008 11:02 pm
by speedracerles
thanks alot, Im trying now to fine all of these parts so i can get started, do you know who makes good down pipes for the T3/T4 turbo and also I want to instal a BOV too. I saw the pics in one other post on here but I need to know how to do it...LOL Hit me up on here or PM me....Peace
Posted: Thu Aug 28, 2008 1:16 pm
by speedracerles
So...
http://isuzupiazza.com/photobucket/leslie photos-3.jpg
Im looking to hook this one up first....
Posted: Fri Aug 29, 2008 12:27 am
by Madcat
Looks good. wheres pics of your other one???
Jim
Posted: Fri Aug 29, 2008 10:49 pm
by speedracerles
I have to take them, some new ones I mean. They will be up in a few days. Thanks bye the way.
Posted: Mon Mar 23, 2009 4:04 pm
by speedracerles
I have the other one's up now if anyone wants to look at them....
