pic
Posted: Sun Sep 18, 2005 11:55 am
by golum
Posted: Sun Sep 18, 2005 12:02 pm
Whatever it is running it needs a new front seal by the look of the puddle underneath!
Posted: Sun Sep 18, 2005 9:51 pm
by Chris
Are their Piazza's which dont dribble abit of oil here and their.. Tell me!
lol.. Seals Seals all I can say.. Do not buy those shitty seals from Repco and others. Go to a seal place and it will cost around $30-50 for a new (maybe even custome) made one but it is well worth it.
Posted: Sun Sep 18, 2005 11:08 pm
I think that Piazza is KilCoys, Matt posted in the Aus Events section. Ran a 16.2 standard and 15.7 on 9psi from memory.
Common problem with the 4ZC1 is to spit the sump gasket out. The oil breathing setup is restrictive, and that air pressures got to go somewhere. If your rings are good, its usually the dipstick or the sump gasket. A mate went through 4 in 2months. Ouch.
Posted: Mon Sep 19, 2005 9:41 pm
I got some ACL front and rear crank seals here and they wer shit cheap really, rear was about $15 I think and they don't leak....yet!
Posted: Mon Sep 19, 2005 11:38 pm
by Chris
By my experience, those cheapo seals tend to be black and quite softer than the better once. Also the cheapos have a spring around the ring while the good once dont.
Posted: Tue Sep 20, 2005 5:43 am
The ACL ones I got were pink coloured like the original Holden ones are and have a double lip. Most of the leaking problems can come down to the groove in the shaft from old seals. Some times a different seal will sit in a new place on the shaft but not with rear crank seals. If the shaft is badly grooved you can fit a speedi sleeve, they are not too expensive and do a good job, available from bearing suppliers.
Posted: Tue Sep 20, 2005 2:35 pm
Go to a bearing joint and tell them you want one for a rear or front main. A high temp one. They are made from some special silicone. If your not paying around the $20-25ea they arent the right one. You get what you pay for.
Posted: Tue Sep 20, 2005 6:18 pm
Viton are the best for temperature if you can get one the right size. I use Viton lip seals in high temp Roots blowers with excellent results over Nitrile. As I said before all is wasted if the shaft journal has a wear groove so if the shaft is out get it sleeved or ceramic sprayed, ceramic is quite cheap and no seal will cut a groove in that!
Posted: Tue Sep 20, 2005 9:07 pm
by Matt
Yep thats "kilcoy piazza" he was out there again at the jamboree. Not sure what he ran. I will find out and post unless he is back on here before me.
Matt
