Page 4 of 9
Posted: Tue Sep 27, 2005 11:50 pm
In person you can see a bit better. They are bigger but not by much. Ive got some exhaust gaskets here i will try and take some pics with them as the guide.
Posted: Thu Oct 13, 2005 2:36 pm
Posted: Thu Oct 13, 2005 2:40 pm
I also got one of those non eyelid Nero grilles.. I reckon they look pretty good with the one piece headlights..
Posted: Thu Oct 13, 2005 3:22 pm
by Chris
Fark!! Where de hell did you get those delorean lights from also they look quite similar to the Isuzu duals.
But wouldnt the DMC lights on high beam shine in theleft direction which would mean you wouldnt get a RWC for it?
Posted: Thu Oct 13, 2005 3:29 pm
Oh yeah I got the 3 engine control computers (fuel, knock, and turbo).. While the fuel computers microcontroller is rebranded a JECS i'm sure it'll be the same as the Pintara one I pulled apart where they hadn't rebranded it and it was a Hitachi 6301. So ive gotta find a ROM reader now.
Also just checked the turbo computer it's running a Motorola 68HC05.. So that would be cool if i can figure out the program it could be reprogrammed for more boost.
Posted: Thu Oct 13, 2005 3:30 pm
Chris wrote:Fark!! Where de hell did you get those delorean lights from also they look quite similar to the Isuzu duals.
They're proper Piazza ones got them off a guy in brissy who had a JDM front cut. He put the engine in a Gemini so didn't have any use for the lights. So they're legal for RHD Piazzas.
Posted: Thu Oct 13, 2005 8:04 pm
My original crossmember is a bit farked so i'm gonna use this one.. Gotta modify it a bit to accomodate the crossmember braces. Gotta weld some nuts in and seam weld it a bit..
This is the difference
Posted: Fri Oct 14, 2005 1:28 am
The end of the cross memeber at the bottom of the pic is open isnt it Bugle??? I wouldnt bother trying to captivate the nuts, just bolt em in as long as you can get a spanner in there. Your not planning on pulling it out again in a hurry are you??
Whats the hole for i can see part of in the one on the left out of your car?? the hole in the top of the crossmember??
Is that an import bumper and indicators?? Where do you put the park lights with the std headlight setup??
Im interested in your findings on the computer chips.
I actually prefer the nero grille and the std lights over the twin setup.
Posted: Fri Oct 14, 2005 1:39 am
There should be enough room to get the mig in there to weld some nuts on. Can only fit a spanner in there if the suspension arms aren't bolted in.
That hole is just a stiffening flared hole thing. Both ones have it.
Yeah import bumper and lights. It has the parkers as normal just they're orange. I dunno if that's defectible but if it is the RB Gemini lenses with clear parkers will fit.
Posted: Fri Oct 14, 2005 2:04 am
I rekon a better look would be all clear lenses and coloured globes and the clear side lights.
Posted: Fri Oct 14, 2005 2:15 am
Clear side ones might look alright.. I like the orange ones in the bar though.
Posted: Mon Oct 24, 2005 7:01 pm
my post disappeared ohwell
Here's the crossmember done
Here's the battery tray section cut out now I gotta make a piece of steel fit the hole.
Posted: Tue Oct 25, 2005 8:03 pm
Posted: Wed Oct 26, 2005 2:15 am
Hey thats magic Bugle. The hole is gone.
How come its not welded in yet??? You got a bunny suck in your welding helmet???
Posted: Wed Oct 26, 2005 11:16 pm
There ya go! Gotta smooth it all off now..
