To do that you have to:
1. Remove airbox & airflow meter assembly
2. Remove plate holding the snorkel
3. Rotate snorkle to point down/forward a bit
4. To reinstall plate put the snorkel through the hole then slide it down getting the plates holes to line up with the studs, you have to kind of force it out enough to get the plate over the bottom studs as the snorkle is trying to prevent you from pulling the plate out far enough to get over the studs.
5. Reinstall airbox/afm
6. Maybe make some ducting to go from the hole in the front bar to the intake
