If your upgrading to something better than the Piazzas crappy mechanical distributor you may need a CAS. Ive taken a line up of all the 4Z distributors.
The 4ZE1 distributor could be your answer. You could possibly run it with the cap or with out the cap as a direct fire on coilpacks. At a later date i hope to post up some more detailed pics of one.
From the top down in the first pic and from left to right in the second.
4ZB1 1.8L
4ZC1T 2L EFI
4ZC1 2L
4ZD1 2.3L
4ZE1 2.6L EFI
As you can see they are all the same with the excepton of the 1.8L distributor which goes into a smaller hole. If you look closely you will see theres no step and the O-ring seal is higher up. They all have the same shaft length and the same gear drive.
The Piazza and the 1.8L shuttle share the same coil/module arrangment.
