I thought it might be easier if I just made one post with all the things I'm after as they are getting lost in the mix. If anyone can help please let me know:
* Isuzu front sports bar - white
* Interior plastic trim in brown (but not too fussy) that goes around the passenger door window at the top
* Driver side electric window assembly (regulator) includiung brackets and cable
* Turbo heat shield
* Black seat belts and fittings
* Whatever you call the thing that goes on the floor in the boot (I currently have a plank of wood with carpet over it!)
* The plastic pin that holds down the ashtray/lighter part on the drivers side door (it's the bit closest to the lighter on the underside)
* circuit board - working - for the LH controls (heater side)
That's pretty much it. Once I get the cosmetic stuff the final transformation can begin so I'd really appreciate any help anyone can give. Thanks in advance
