WTB dash and headliner
Ghost
Post by Ghost »
Does anyone have a spare dash and headliner for an 86 piazza xl?
1986 Piazza - 1984 Piazza
1986 Heron MJ1
how much of the dash do you need and if you have the head lining board they are piss easy to re trim, spray on glue and a bit of light material from spotlight. If you don't have the board i can help with one of those
Ghost
Post by Ghost »
I need the vinyl parts of the dash and glove box as it is all peeling up.
1986 Heron MJ1
As they all do eventually, don't really have a decent dash left, last one I had went to another Auckland member. They are not too difficult to re cover once removed from the car but make sure you don't damage the foam underneath the cracking vinyl. I might have one left that could be recovered to make a faster swap than having it out for the duration of the job. swapping the dash is a lot easier than you might think once you know the trick to it. takes about 20 minutes to get out. With the steering wheel off it is easy to remove the complete instrument and switches binnacle as a complete unit. After that the dash is p.o.p to drop out.
If you want to see how it all goes give me yell by PM with your contact number and i'll give you a ring
