I have started to rebuild the engine of my Isuzu Piazza 87.The car is a non-turbo and has auto transmission.
The engine was first of all dirty,full of mud and oil.
I had water and oil leaks all over the place and it ran very bad.
I have bought and assembled new gasket set,new piston set,i have reshimed the head,i have bored the cylinders,i have cleaned everything in it,i have painted all the parts that should have been painted,new spark plugs and wires.
I have cleaned the injectors,wich was a bad ideea,cause the guy that did that,did the worst job ever!After cleaning,two of the injectors were clogged and did not throw gas.I had to take them off an clean them using a device made by my mechanic with a fuel pump,hoses and some cleaning substance.
I still have to tune the engine,wich is running like hell,but i suspect a hose or an electrical problem wich is very hidden.
i will attach pictures with the stages of the reparation.
The next move would be to paint the car,change the gearbox with a manual one and then paint it.
I will keep you up to date!
Tell me what u think about it.
Ride smooth!
