help on piazza loom
- Junior Member
help on piazza loom
hi this might sound a bit stupid but can any1 tell what all the plugs are??.... i dont have car here to find out. if it helps i can send any1 willing to help better pic
help me
Buy a manual fella. Its got pictures of the connectors and plugs. Posting up diagrams is frowned upon.
Or you could lay it out over a manifold theres not that much for it to connect to, shouldnt be that hard to work out.
Dont quote me.
2 looks like the TPS.
3 thru 6 are the injectors.
7 could be the distributor but if memory serves it should be a square plug no wire hold in clip it should be a plastic tab.
8 looks as if it could be for the idle or cold bypass or whatever it is.
Green and white multi pin plugs are the loom connectors or course.
The small green plug next to it is possibly for the coil/module, you could check the wires to confirm that.
Id say the plug for the dropping resistor is off to the left out of the picture.
As for 1, 9 and 10 well who knows. No 1 would be for the temp sender possibly as its in the right spot. The others i dont know. Im sure theres a VSV on the Piazza thats possibly number 10.
Im just going on my Rodeo memory.
Cheers, Bob.
Dont quote me.
Cheers, Bob.
- Junior Member
Thats why im not up for diagrams posted up on the forum here.mcmuthafart wrote:i cant find a manual went to repco and they didnt even no what a piazza was
First reason is if youve got a factory manual chances are it cost you over $150 to buy.
Second reason is that someone has copied the whole factory manual onto CD, that took a lot of time and for $20 thru APC its a bargain. Contact Chris or Poida.
- Junior Member
