Boss Kit
Boss Kit
Hiya,
I'll be putting a new steering wheel on my Piazza shortly and was wondering if anyone knows which boss kit to use and/or where to get one?
Cheers
EDIT by BOB: I dropped the pic heres a link to pics of the car. http://isuzupiazza.com/forum/viewtopic.php?p=4877#4877 I hate the big pics, im gunna hit Chris up for some thumbnail, click it make it big gear in the isuzupiazza pic upload thing. Bob.
Cheers
Possibly a Rodeo (which should be the same as a Jackaroo one) one with the indicator cancel roll pins removed. Id have to check, ive got one that was in a piazza but without the horn hooked up and ia dont remember why that was. Im not sure if the indicator cancel thing was working either, that a weird setup the Piazza has with the friction disc.
If i remember over the next few days i will take some pics of it.
The bighorn Irmscher has a three spoke Momo and the boss kit fits the Piazza spline but it sits high up on the column being a flat form centre pad and the horn pick up won't reach so needs a spacer to bring the slip ring down far enough. I have one i need to do but haven't got around to yet. the Bighorn wheel isn't that nice but getting the boss kit sorted opens it up for any Momo or Momo copy.
Can't do that with the bighorn boss as it sits a good 50mm away from the horn hot tongue. Plan is to make a black plastic spacer bos to attach nder the wheel and relocate the slip ring to the bottom of the spacer and fix the spacer to the underside of the boss and bring the contact through to that.
From memory my factory momo has a differantly spaced backing horn slider bit, the boss could be the same as bighorn, the momo wheel is the same. I do have a couple of factory momo boss kits lying around somewhere also one to suit other type (also fit momo) but wheel was close to contol switches etc but was o/k when you got used to it.
The one ive got here must be a Gemini one. It had a big gap but the guy had put a horn button on the side of the steering column cover. He had the lid off a black spray can screwed on the back of it to fill the gap.
If i had my own lathe i could spin something up. Bugle might be the man to talk too, send him the boss with some bucks in the box and he can send you back the done deal.
Its not too hard to put a sports wheel on if all the Isuzus share the same spline for the steering wheel. If it was a one off spline you would have a hard time.
Hey Gene, its time to pour some fresh gas in your Nero and dust of your passport and come north of the bridge to check out my collection. We are hoping Madmike can have his on the road by Queens birthday weekend so we can do a meet somewhere but I'm short of one driver at this stage to get them all out. I'll need to get Graham the haggis to pop over and help out.From memory my factory momo has a differantly spaced backing horn slider bit, the boss could be the same as bighorn, the momo wheel is the same. I do have a couple of factory momo boss kits lying around somewhere also one to suit other type (also fit momo) but wheel was close to contol switches etc but was o/k when you got used to it.
Here's what i've got
TF/G Gemini steering wheel
Piazza steering wheel
Piazza boss and Bali spec momo ripoff
No idea where that Piazza boss came from, came on my car when I bought it..
The Gemini horn ring is about 30mm further out than the Piazza. However the rim of the wheel is a different offset between the two so to get a Gemini boss to the right position you would have to machine about 10mm off the back of the boss and drill a hole for the cancelling thingo, then space the horn ring out.
