I need to know the basics and i hope im not repeating other newbies questions but here goes...
What known problems do these engines have, do the water ways slowly but surely wash away and cause the fluids to mix?
What can the stock internals take and can you get uprated parts off the shelf like cams, valves flywheels, clutches etc. I've looked everywhere but as yet haven't found anything at all, i've even looked further a field (az and the states) as you chaps seem to have bought a few more than us Limeys but still can't find anything!
I will be looking at replacing the turbo for something a bit beefer and having a custom made manifold but can the std ecu be re-mapped or chipped or am i looking at getting something thats mappable?
Ok so thats probably about all your going to want to read regarding engines so what about diffs, my piazza is a HBL model with LSD and when i collected the car i jacked up the diff and spun the wheels and sure enough they rotated the same direction, brilliant i thought but unfortunately after hading over the cash and i got to have a drive and performing some tests the LSD is shagged! What i was hoping is that it can be rebuilt but unsure as to the costs and it could be cheaper to replace with a good known working one but i've not found one for sale as yet...don't suppose anyone has one for sale do they, don't mind it being shipped over seas but just need to make sure the cost isn't that high
Ok so thats diffs and engine questions asked....now onto trans...
After picking the car up, driving 140 miles home faultlessly i've now lost the clutch, fluid all over the garage floor and pedal hits the floor without any pressure and then stays there...i've never worked on a hydraulic clutch before and i know nothing about this car but i've found a little cylinder next to the brake servo thats empty of fluid but what could of caused it to have emptied? What is thats at fault, is it the slave cylinder in the gearbox (i think thats what its called anyway)
Right, i think thats enough for this post, sorry to waffle on so much, i've got a lot to learn am im hoping you knowledgeable people can help me.
Regards
Jacko
