Engine Prep??
Posted: Fri Nov 03, 2006 1:17 pm
I am getting into my piazza in the weekend finally
I was toying with the idea of selling the 4z and using something else but in the end i come to the conclusion you guys are getting pretty good numbers out of the 4z's so i'll go down that route.
I'm going to keep with the standard bottom end at the moment and do some head work. Which leads me to my questions.
What do you guys do to the heads to make them flow more??
Are larger valves available to fit the 4z heads??
what type of head gasket do you use?? Is the standard one good enough for more boost?
