I also got the shift fork and a slave cylinder.
the bell is suprisingly light weight, i thought it was plastic when i first pulled it out of the box!
not sure wtf that other hole is for on the mounting face...
you're correct, I was so excited to get the bell i didn't bother to unwrap the slave to inspect. or use logical thought.Slave cylinder hole on the right???
that's the plan. I need to get the 'retro-fit' Tremec box with the T5 adapter plate.You can bolt a T56 up to it can't you?
stock rating is 400lb-ft, the GM/Viper hybrids are rated to 650.They'd be pretty strong..
Impulsive Yank wrote:you're correct, I was so excited to get the bell i didn't bother to unwrap the slave to inspect. or use logical thought.Slave cylinder hole on the right???![]()
You could use an internal slave cylinder.Impulsive Yank wrote:one thing I'm not sure of now is the slave. it looks like the stock spot might interfere with the body of the trans.
