Wiring - connecting alternator wiring to g200w loom?
Posted: Mon Mar 29, 2010 8:08 pm
just a question regarding the voltage regulator and where it supplies the ecu loom..
Basically my g200w came as a complete loom, but was missing the alternator/voltage regulator wiring - which I've now aquired a voltage regulator & for the most part alternator wiring..
I've worked out where to plug everything except the following:
from the ecu end its the same type of plug as the voltage regulators coloured black plug. Wires from that plug to ecu:
Blue, Green yellow, blue white, blue yellow, blue black, blue red.
My problem lies in the next part, the wiring from the alternator/regulator end. Im left with :
White , white blue, white red black, white black.
The white red has a fusable link on it, and continues white red.
The problem is all the whites dont go into any plug as the wrecker I sourced them from chopped it off! Also any genius will work out that I have 6 "blues" and 4 "whites". There is also another fusable link, but thats further down the alt/reg loom (this will be to the battery)
hope you can make some sense of that, Im also getting a Japanese girl on one of the nz forums to translate the wiring diagrams from the japanese workshop manual..
