water in wheel well
water in wheel well
just got a little question hopefully someone can help me out. i am looking at installing a sub into the wheel well of my piazza but have noticed that there is sometimes water sitting in the bottom of it. from what i am told it is pretty normal for water to get in there that is why they rust out. i am just wondering if anyone knows where bout the water comes from and how to stop it. please help
Just use a hose with a pressure nozzle. Shoot water at any place where you think water might come in (including from underneath) and you'll soon discover where the water comes from....
Business CD Solutions
I've noticed with the red one water comes through the hatch seal. Wasnt much and only happend when it rains heavily.
here are a couple of other traps to watch out for. The corrugated rubber hoses holding the hatch wires, if they split water seeps back into the roof cavity and drips down from under the roof lining rear trim, If you don't think it is them then take out the hatch hinges (one at a time is manageable), and make sure the plastic backing shroud isn't split as that is another sneaky Piazza trick. It can cause rusting out of the panel as well but a quick look under the lining trim will tell you if that is the case. If it does rust there and you ignore it you will have an open backed car one day when passing a stock train at mach 5 and the suction grabs the hatch.
Good Game...Good game
yeah i thought it was the seal but i can't seem to find any water on the carpet it's only in the wheel well (which is good because i have my 12 stacker and master control unit for my stereo in the boot) but i think i might have to get in the back and get someone to spray the car with water.
also is anyone here good at maths? i need to figure out the volume of the wheel well to see if it is big or not big enough for a 12 inch pioneer sub
oh yea that one's a bitch..wedgenut wrote:here are a couple of other traps to watch out for. The corrugated rubber hoses holding the hatch wires, if they split water seeps back into the roof cavity and drips down from under the roof lining rear trim, If you don't think it is them then take out the hatch hinges (one at a time is manageable), and make sure the plastic backing shroud isn't split as that is another sneaky Piazza trick. It can cause rusting out of the panel as well but a quick look under the lining trim will tell you if that is the case. If it does rust there and you ignore it you will have an open backed car one day when passing a stock train at mach 5 and the suction grabs the hatch.
The formula isn't too difficult but to get it exact is tricky due to the shape when there is a much easier way. I'm not trying to be funny here honest but fill it with water!. Fill it using a measuring jug and you will get the exact volume. Some old greek bastard discovered something like that a few years back, was it Archimedes? he was good bloke he went on to invent a new kind of screwing i thinkalso is anyone here good at maths? i need to figure out the volume of the wheel well to see if it is big or not big enough for a 12 inch pioneer sub
Formula for volume = L x W x H
where:
L = Length of box
W = width of box
H = height of box
Simple isnt it? As for the wheel well question, im pretty sure its done the following way...
Area of Circle x height. Area of circle is found by Radius x Pie^2
where:
L = Length of box
W = width of box
H = height of box
Yeah your right, just re-read that now and realised i wrote it out wrong
Been a while since ive done Area [haha try year 7], amazing how you learn way harder things and remember them [like calculus] yet forgetting the simple shit is easy. lol
Like the man said, Area for a circle = Pi X Radius^2
