WTB - 86 PIAZZA LH/F Suspension bits needed!!!
Hello all,
some nice gentleman just decided to mount the gutter and hit my pride and joy black piazza, smashing lh/f caliper, stub axle and lower control arm. also wrecking bonnet, guard and two of my 18"s.
the body work i can handle but trying to find bits is hardwork in the act, if anyone in aus has
LH/F caliper
LH/F stub axle
and a
LH/F Lower control arm.
and would like to sell them and post at my expense PLEASE LET ME KNOW!!!
thanks!!!
LH/F caliper
LH/F stub axle
and a
thanks!!!
devilishdesigner
- Junior Member
Piazza Guard
Hey mate actually pretty keen on the guard how much you want? and are you keen to send to a.c.t for me? if not where you located i could come get it if its not too far!!
let us know, cheers
let us know, cheers
devilishdesigner
- Junior Member
$50 sound fair? $20 for the bonnet and plastic eyelid (no opening mechanism) if you want that (only needs a respray as it's been sitting on gravel next to the shell for a few weeks, happy to send them via courrier if you want to organise one (i'm near lilydale, out east of Melbourne) or I'll be up on the coast near Ulladulla, basically directly east of you for a couple of weeks mid jan if you feel like a bit of a drive.
devilishdesigner
- Junior Member
If no bastard comes to your assistance i can help with caliper and lower control arm no problem, I have bucket loads of them. I might even have a stub axle kicking around as well but you need to consider the cost of getting them over the ditch, thats the trouble with big lumps of steel and iron, they tend to be Heaveeeee!
However if really stuck it is an option.
Let me know
Let me know
I can sort you out with a lower control arm.
Do you need just the straight out arm off the cross member or do you need the castor part of the arm as well (the cast bit)???
For a stubaxle you may be able to do a deal with Poida.
You can find him on the Ozgemini forum, Username Germinator, he bought i think it was a pair of LH stubaxles and then borrowed my Spare RH one off me. Or the other way around.
Poida also has a Gemini twin cam forum.
Either way the Caliper and stubaxle probably wont be easy to find.
I have one set of Piazza front brakes left to sell.
$450 posted, the hoses are there but you will need to get new ones made as one is split.
Thats about the best i can do.
Hello everyone, thank for the help
I found that gemini stubs work, but gotta use gemini wheel bearings and outer tie rod ends, whuich are much easier to find than piazza stuff.
and piazza calipers are availible on american ebay for around $40 brand new, not remanufactured.
little unfortunate i had to run gemini stubs but now there on there you wouldnt know the difference.
thanks again for all your info guys!!!
