I'm baaaccckkk!
Skrilla
Post by Skrilla »
Just changed the plugs cap rotor and fuel filter.Awaiting a PCV valve next.I want to change the coolant,oil and filter next day off.The trans has a leak so my concern is to fix it or just do the 5 speed conversion.
I suppose it comes down to how bad is the leak? AFAIC I would leave it and check oil level more regularly until you're ready to convert.
Skrilla
Post by Skrilla »
Its cant be driven bad,lol
Skrilla
Post by Skrilla »
I got a few leads on a trans but got my hands full with so many other projects.I do for big plans for this one though I will keep this thread alive .
Looking forward to further updates.👌
Skrilla
Post by Skrilla »
Cant be NOS parts.Luckily I found an Isuzu dealer in CA that has a decent stock of parts.I scored a new sunroof seal(mine was DONE),I got 2 factory key banks(I'm a stickler for OEM) and a new oil cap.I will continue to restore this car piece by piece.I think I located a 5 speed trans then will work on restoring the whole suspension.
Skrilla
Post by Skrilla »
Old sunroof gasket
Like new now
Urethane end links turns out they are the same as the old camaro
What's the part number/reference number of the urethane end links?
Skrilla
Post by Skrilla »
Skrilla
Post by Skrilla »
Good day in impulse history.A friend scored some rare interior parts from a junkyard.These parts are broken on 60 percent of the cars I found.After this my interior will be perfect.
Skrilla
Post by Skrilla »
Guess whats in here?? :) I will post more pics as the transformation takes place.
Post by archangel62 »
The swaybar link bushes are fairly generic, I've used Gemini (I-mark) items. Do you know what's causing the leak on your trans/gearbox? If it's something like the seal on the output spline, or a loose drain plug, it could be an easy fix.
