Suspension Specs.
Suspension Specs.
I translated this stuff from a Japanese website a couple of years ago. I posted it up on Isuzone, but there are so few first gen members on there that it was largely overlooked.
Some of the translations are quite literal.
This Info is specifically for the 88-89 Cars with the Lotus tuned suspension.
Coil Spring Rate [kg/mm]
Type Year system
IMPULSE 88+
Front: 4.3
Rear: 2.3 - 4.8
Remark: HBL
Coil Spring spec (HBL - Handling by Lotus)
HBL(MT) 88+
FRONT:
Free Length(mm) 400.0
Wire(mm) 14.5
Outside(mm) 116
Number of active coils:9.83
Total number of coils:11.58
Identification Color: no info
REAR:
Free Length(mm) 303.5
Wire(mm) 10.8
Outside(mm) 123.6
Number of active coils: 5.5
Total number of coils: 7.25
Shock Absorber rate [ (0.3m/sec時)kg ]
HBL
Year 88+
Front
Extends: 82
Shrinks: 30
Rear
Extends: 63
Shrinks: 64
[kg/cm^2]
20.6(F,R)
sway bar. mm
23 front
20 rear
Suspension Stroke [ mm ]
type: HBL
Year: 88+
Front
Stroke- 143
Most expansion- 390
Most reduction length- 247
Rear
Stroke- 158
Maximum expansion- 748
Minimum length- 320
Front Alignment
Type: HBL
year: 88+
toe in: 1mm
caster: 4°30'
camber: 0°00'
Here are the specifications for the Irmscher suspension.
IMPULSE
Front: 4.7
Rear: 1.4 - 7.2
Remark: Irmscher
Coil Spring other spec
FRONT:
Free Length(mm) 383.0
Wire(mm) 14.0
Outside(mm) 101.1
Number of active coils: 7.93
Total number of coils: 9.68
Identification Color: No info
REAR:
Free Length(mm) 339.5
Wire(mm) 9.2￾`12.5
Outside(mm) 106
Number of active coils: 7.63
Total number of coils: 9.13
Form: Irmscher
Front
Extends: 87
Shrinks: 35
Rear
Extends: 130(92)
Shrinks: 38(38)
[kg/cm^2]
no data
sway bar. mm
25 front
17 rear
type: HBL
Year: 88+
Front
Stroke- 152
Most expansion- 397
Most reduction length-245
Rear
Stroke- 197
Most expansion- 488
Most reduction length- 291
Front Alignment
Type: Irmscher
toe in: 1mm
caster: 4°30'
camber: 0°45'
I can't tell from these specs alone which version is the better handler. Was there ever a comparison test published between the two tuners?
Post by archangel62 »
After giving that a quick look, I reckon the HBL would have better turn-in at the cost of slightly more oversteer, based on the swaybar sizing. The HBL would also be slightly more linear in the back end, based on rear shock absorber valving and a slightly less progressive springrate, although it'd come down to driver preference as to if that's better or not. I'd prefer it, but the ride might be marginally less forgiving over bumps, albeit still not too bad.
The camber setting is interesting, however, with HBL at 0deg, which would be good for tyre wear and straight-line braking, but pose a notable loss to turn-in over a negative cambered setup. The Irmischer notes camber, but I can't figure out if they mean negative (good) or positive (bad). At the end of the day, though, that's easy to adjust yourself.
Thanks mate. I notice the HBL springs are softer all round, especially in the rear, compared to Irmscher, but they've gone for the stiffer rear bar setting, which kind of negates the stiffer front bar. Would that translate to less body roll for HBL? As far as spring rates are concerned I would probably prefer the HBL softer rate and let the Konis control the rebound better, and then use the Irmscher stab bar specs to dial out the understeer. It's hard to work out precisely what the tuners wanted to achieve, but I'm more surprised there doesn't seem to be any head-to-head comparisons published. I'll have to keep a closer eye on any Japanese articles.
Pity none of the ICCA guys are here (Isuzu owners Car Club of Aus - nee Bellett-Gemini CC of NSW), some of them race(d?) Piazzas.
My Guru once gave me a run down of the variations (& GMH stuff ups) but any memory of brief notes taken are well hidden now. And Guru has since left the Marque as well as any sites (the latter as I have too LOL).
Not that I was that interested in Piazzas at the time, it was more the G200W overlap (since I didn't consider the 4ZC1-t 135HP nor 180HP worthwhile).
And I can't recall who was racing Piazzas so I don't know whether they are inies or outies. (Coincidentally, parallels with female front bums may be applicable.)
twocan
Junior Member
Junior Member
Re: Suspension Specs.
Post by twocan »
I know this is super old but this information helped me a heap when i was trying to get some springs for my HBL car to go a little bit lower.
I made some measurements with the suspension disassembled and basic calculations (using the formula MR = (lower arm length / spring distance) * sin(spring angle) and it looks like the motion ratio based on the measured dimensions for
- the front is 0.536
- the rear is 0.80.
I.e. 100mm of travel at the wheel = 53mm of spring compression etc. the dimensions measured are as per below.
front
Rear
I then used an excel sheet to calculate and compare the motion ratio's and the measure corner weights of the car to see if the measuremnts and calulation came up with the same spring rates and lengths to what i measured which they did. Also Faulkners in the UK measured the actual spring rate of the HBL spprings in my car and this is the response
Results
Fronts
390 mm free length
245 lbs/” average (4.375202kg/mm)
Random fitted of 300 mm load 874 lbs aprox
c/g x 1 86.4 i.d.
nearly closed not ground 87.3 mm i.d.
Rears
312 mm free length
125 lbs/” average (2.232246)
Random fitted of 200 mm load 508 lbs aprox
c/g x 1 99.8 i.d.
nearly closed not ground 100.2 mm i.d.
fronts
rears
dont have photo's
and this i the calculation sheet with notes etc that i used. hopefully this is of use to someone else in the future.
piazza suspension and spring calculator.zip
(9.92 KiB) Downloaded 1345 times
I will post more information about the custom springs made in the custom springs post.
Thanks for the detailed write-up twocan. Brilliant stuff. Although my car is lowered I’ve been thinking about redoing the rears as they are loose and kind of want to fall out when jacked up. Maybe slightly thicker rubber/nolathane pads to close the gap, but haven’t found anything yet.
twocan
Junior Member
Junior Member
Post by twocan »
Yeah I did get a set of escort lowering springs for the rear from one of the other piazza guys but they weren't captive with the spax shock I have. They ended up getting custom made shorter shocs from Gaz in the UK to solve the issue.
I struggled to find shims of the correct dimensions as I was thinking of try to get the corner weight correct ish, best I found on ebay was 3mm thick rubber washers for 1000l bulk bins. I think there are 2 inch lift spacers for 4wd's that might fit though havent had one physically measured.
:tonqe: funny you mentioned the escort lowering springs and my rears are off Escort MK2 front lowered springs (variable rate). My shocks though are Koni. Because the springs are slightly different diameter to factory ones the rubber seats aren’t sitting properly in the springs. Ideally want this fixed with new seats and if the rear height was increased 5-10mm I’d be happy.
:profileright:
:profileleft:
twocan
Junior Member
Junior Member
Post by twocan »
Yeah i think this is what some of the guys have done with custom shock lengths and it works OK, i don't like the idea of non captive springs as the country roads google seems to direct me to travel on would just be asking for me to have one fall out. i think you can get spring spacers for landrovers and the like which might help. i tried with some rubber seals from pipes that were the correct diameter but i don't think they are the correct way to do things.
Way ahead of you twocan. I picked this issue up as well, and like you, not a fan of loose springs either. I persevered with these springs because I liked it’s progressive rate design and inherent ability to absorb small bumps smoothly. Through some trial and error I sorted out what spacers I needed to capture the springs. I initially used the standard rubber bushes but it was sitting too low as the standard upper/lower spacers were slightly too small for the new slightly larger diameter (about 11mm wider) rear springs, causing parts of the spring to not seat properly. It was causing the rear suspension to hit the bump stops far too often.
That being said, below is the top/bottom spacer combination I found that works for these cars if choosing to go with these rear springs. Spring capture solved.
The spacers are nolathane and offer superior durability to the standard factory rubber units. While rubber offers supple dampening more and ride quality it does come at a cost with inherent cornering softness. Cornering appears to be much flatter around bends now.
A couple of notches taken out of the nolathane to accommodate the bolt heads
At 6mm thickness the new bottom nolathane spacer is about 3mm thicker than standard
Bottom nolathane spacer
Springs need a little extra effort to squeeze back in and out once the new nolathane spacers are installed. The bottom spacer was not installed at this point.
Top nolathane spacer
twocan
Junior Member
Junior Member
Post by twocan »
ahhh, nice find, i spent hours looking for things like that but couldn't see much else, i'm sure that will be super useful in the future and for others on this path.
Agreed. All about sharing ideas and options for all in this community to take advantage of.
