Ditto, nice pics. And nice car! VERY nice.
The G200W Piazza i saw was in 1980. I have a couple of pics but they are on this ancient technology called "prints" unless I was still using slides, but I do recall a hardcopy (print). I should be able to find it and scan etc but they are probably of limited value. I think one was of the digidash and the other from the front with bonnet down. And quality is limited - probably taken on my Minolta 16mm camera and underlit.
Your dash is analog. That is rare here and often sought my many due to troubles with digidashes (not surprising after all these years; capacitors alone tend to dry up after 20 years...).
And yes, your EFI/EMS is ECGI which (afaik) is the typical licensed Bosch jetronic system (JECS? JIDEC?) with a mechanical dizzy.
All Piazza G200Ws were ITEC with the locked optical dizzy and electronic ignition timing. (All G200Ws were EFI but the 117 used mechanical dizzy and a
Bosch. Trivially though there were "never" any (factory) G161W EFIs, there were factory prototype 117 G161 EFIs which literally used Bosch - injectors, the EMS, and even a Bosch JFUX 4 dizzy with its extra 2 injector-bank switching points. A mate has one of those factory 117 EFI prototypes.)
All Aussie Piazzas were the ECGI 4ZC1-t turbos. 700 units were imported. Manuals have LSD whereas autos (afaik) were open diff. (Yes, there were autos, and they were the 4-speed types.)
The Aussie Piazza had the typical Isuzu diff - ie, banjo type compatible with all solid axle Isuzus from circa 1965 until the 4ZE1 2.6 EFI circa 1989 though diff ratios vary - ie, typically 3.9 for passenger cars (4.1 for Florians) and tyically 4.55 for commercials (Wasp, Rodeo, Jackaroo). IE - they were not the torsionbar Salisbury/BorgWarner types like Geminis and earlier Piazzas. (The Piazza was built on a Gemini. The 117 was build on a Florian.)
FYI - though all pre-4ZE1 diff banjos interchange - eg, I had a 1985 Jackaroo LSD in my 1965 Wasp (Bellett ute) - crown & pinions may not. IE - Florian crowns were 8 bolt whereas Piazza, Jackaroo & Rodeo (and I believe LUVs and KBs) were 10 bolt. But most crown & pinions otherwise should though I have yet to confirm... I haven't yet retrofitted my scavenged auto Piazza open diff 3.9 crown & pinion into my Jack/Rodeo LSD banjos.
But I suspect your diff is the BW/Saliisbury type as was the 83/84 G200Z Piazza I
recently inspected. (Damn - I wanted its ~3.5 ratio gears for my Florian!!)
Strength wise I'm not sure. Though I'm keen on the bigger 4ZE1 diff for my 400Nm Florians - in part for their disc brakes - I'm not sure it's warranted strength wise. I did twist a 5-speed Gemini box's output shaft (and I never did burnouts!) but even the old Florian diff (with Bellett 8-bolt 3.7 crown & pinion) presented no problems. And I've heard of 500HP machines using pre4ZE1 banjos/diffs without problem -not that they had anywhere near the torque I had (300Nm @ 2,000 RPM).
But yours is not the banjo type.
There are lots of writings on other forums about Gemini diff upgrades (eg OzGemini) but many such writings are suspect. ("Poida" on OzGem and elsewhere summarised & clarified the different Gemini diffs. I'm not sure what he wrote about their strength.)
As to your dizzy and igCoil, the normal solution for GZ engines - and ANY G-series engine for that matter (ie, G-OHV, GW twincams, & GS Jap SOHCs) - is the "RG" dizzy which is a Gemini points dizzy transplanted with (early) FWD RB Gemini reluctor guts and ignitor using the RB subharness to/with RB ignition coil if not later igCoils (E-types etc).
But I'm certain yours is already electronic though it probably uses the same antiquated multi-piece reluctor and inferior ignitors that early systems used (eg GWs).
WRT the different advance curves I have generally found all G-series to be overlapping in specs so RG swaps aren't a big issue. But my view in recurving mechanical dizzies is to NOT - use an electronic timing unit instead which you can remap yourself later. The initial cost may be similar but the mechanicals wear and you can't "reprogram" their curve.
You may be able to swap direct for an RG setup. Unlike the 4ZC1-t which has limited advance (being turbo, ie ~5 degrees??) and knock sensor interaction - and the 4Z dizzies run the opposite rotation anyhow - I think yours is completely standalone.
The only issue is RPM sensing for the EMS but that is either from the ignitor output (which is the same as points and generally the same for all - ie, ground firing) else from the reluctor and the RB/RG reluctor should be compatible with all (being a lower impedance than older systems).
Alas I'm not sure of your ignitor capability - early ignitors (and shit systems like
Peteronix points conversions) still required igCoil ballasts else were limited in current capability (RB ignitors incorporate current limiting so ballasts can be discarded) - but otherwise I'd say
for Pete's sake don't get a can-type igCoil. Modern transformer types (E- & C-type etc) shit all over cans though I know some sites say otherwise. (I'd like to investigate such claims but I couldn't be bothered; I found enough flaws in their other statements and arguments.)
BTW - use NGK splugs. Else NGK splugs. Or NGK. (Get the point?) There may be the odd exception where better splugs exist, but from one that gets over 100,000km from the st'd NGK BP6ES (gapped to 1.1mm) from an RG system in a 1969 G161-OHV that cold starts with a battery voltage of 5.2V, I reckon the RG and NGKs are bloody fine.
And don't get sucked in by fanciful systems. Last year I saw a terrific Gemini but it had a $995 Scorcher dizzy (eg,
Holden Gemini Isuzu Electronic Dizzy HEI Distributer Conversion G200, G180, 2L). Whilst I question the performance of such as system compared to the RG, this Gemini had it firing a can-type igCoil! (Was it chrome-plated to boot?). For that money I can convert OEM G200Ws to the 400Nm build!
And a clarification to all readers: When I have mocked Bosch GT40 igCoils for modern use I meant the can types. There are GT40 E-types which fall under the (IMO) acceptable/good modern igCoil category.
And a comment - I've seen much written about igCoils and the
interim use of ballasts (and hence 2-terminal "cranking" ignition switches) and their reasons yet many seem oblivious to the inductance of those "8 volt" ballasted ignition coils etc.
And whilst current limiting ignitors may make any igCoil seem usable, such ignitors may require dwell limitation - ie, put an unballasted GT40 direct on 12V and it may last 15 minutes or longer; do that to a Bosch MEC717 or MEC723 (like I was using on my RG) and they'll be lucky to last one minute. Many modern EMS - especially with COP systems - have dwells dependent on RPM.
I hope my short reply is of some use.
