Contact About Us Links
FAQ - Search - Members - Groups - Register - Private Messages - Log in
in the hunt for power!
Post new topic   Reply to topic    Welcome to IsuzuPiazza.com :: Uniting Isuzu/ Holden Piazza Enthusiasts since 2002 Forum Index -> Show room
View previous topic :: View next topic
Author Message
brendan
PostPosted: Wed Jul 26, 2006 7:09 am    Post subject: in the hunt for power! Reply with quote
This is what helped kill my engine but she went well while it lasted, should go good once i get her back on the road
Back to top
View user's profile Send private message Send e-mail MSN Messenger
PostPosted: Wed Jul 26, 2006 8:53 am    Post subject: Reply with quote
Super Super Looks like alot of fun. T03 yeah? Id really recommend throwing a 4ZE1 Rodeo dist. into it along with a programmable ECU like a MegaSquirt or something.
Youve also got alot of oil around the air filter area like my car did - do you know what it is?
_________________
Back to top
madmike
PostPosted: Wed Jul 26, 2006 2:56 pm    Post subject: Reply with quote
shit man how much boost were u runnin?
_________________
Sideways by choice!!!!!
Back to top
brendan
PostPosted: Wed Jul 26, 2006 5:01 pm    Post subject: Reply with quote
only got to try it for 1 hour, the turbo was stuffed and i didnt know, it pressurised the sump, blew the dip stick out and i lost all my oil, hence my engine is now seized. The car went great with it, there was heaps less lag and it went better with the t3 running 9 psi then it did with the stanard turbo running 14psi, there is was no oil leaking there it is becuase of all the oil that came out of the dipstick hole!
Why do you recomend another dizzy, what is so much better, is it hard to hook up, and are they hard to come by?
Back to top
PostPosted: Wed Jul 26, 2006 7:16 pm    Post subject: Reply with quote
Its a Crank Angle Sensor type, downside is you need an ECU to run it. Would be a lot better than the fixed curve Dizzy thats in the Piazza as std. But youd have to invest in a fuel and spark ECU that will run this distributor.
If the ECU can adjust the timing you get more go and its safer for the motor, provided the ECU is tuned and mapped properly.
Ive got one here that i could sell, its out of a 2.6L 4ZE1 Jackaroo. Ive even got a New cap to go with it as a spare. The caps are a Holden only part and not cheap. You can buy a Bosch replacment rotor for these dizzys cheap at Repco/Bursons etc.
_________________
Back to top
View user's profile Send private message Yahoo Messenger MSN Messenger
madmike
PostPosted: Wed Jul 26, 2006 8:03 pm    Post subject: Reply with quote
shit any idea what the max boost u can run on standard injectors im runnin 10psi at the mo using a vf8 boost comes on quite soft
_________________
Back to top
brendan
PostPosted: Wed Jul 26, 2006 8:34 pm    Post subject: Reply with quote
i had 14 psi running on my std turbo and had no problems, just lots of lag, but i also had a cracked manifold, hence the new high flow manifold and t3 turbo Super
Back to top
PostPosted: Thu Jul 27, 2006 1:25 pm    Post subject: Reply with quote
Is that a R32 Skyline turbo?
The drain is supposed to be at the bottom, the way you've got it there would've kept the thing full of oil and probably did something bad to the oil seals. You can rotate the centre bit and keep the housings in the same positions.
Back to top
rodavo
PostPosted: Thu Jul 27, 2006 2:15 pm    Post subject: Reply with quote
I was about to say the same thing Bugle.
I would put money on that being the cause of the problem. The oil cannot be pumped out of the turbo by the standard pressure pump , you need to run a seperate scavenge pump to suck the oil through if you want to run the drain in that way.
Back to top
brendan
PostPosted: Fri Jul 28, 2006 7:34 am    Post subject: Reply with quote
i didnt know that, could have been the cause for the turbo blowing heaps of smoke and causing crankcase pressure? Which in turn helped me to seize my engine pale
It is a rb20 turbo of a skyline r32
Back to top
PostPosted: Sat Jul 29, 2006 8:59 pm    Post subject: Reply with quote
Dunno bout the crankcase pressure but it definitely would've caused the turbo to put heaps of oil out past the seals..
Back to top
brendan
PostPosted: Thu Sep 14, 2006 9:15 pm    Post subject: Reply with quote
okay need help again,
Engine has been rebuild car is back together, with new second hand turbo oil line at the top, car doesnt blow smoke all seems to run fine BUT The turbo is getting really hot and i just took it for a run tonight and when i got home found that the turbo, manifold and exhaust glowing red!. All i can guess it that the turbo is not getting cooling?
The oil ling has been custom made with proper braided oil line with all the usally connections, The only thing i am not sure about is the old turbo had three water inlets. one of the block, one of the bottom radiator hose and one into the radiator, i am using the one of the block and the one into the bottom radaitor hose.
Will post up pics 2 morrow, any help would be greating appreaciated
Cheers
Brendan
Back to top
piazza-crx
PostPosted: Thu Sep 14, 2006 10:23 pm    Post subject: Reply with quote
my turbo and manfold did the whole glowing-red-hot thing when my head was cracked...
_________________
Back to top
PostPosted: Fri Sep 15, 2006 2:06 pm    Post subject: Reply with quote
Is your timing set right? Just noticed this thread http://www.performanceforums.com/forums/showthread.php?t=67207284
Also you should make a heat shield for the turbo..
Back to top
Display posts from previous:
Post new topic   Reply to topic    Welcome to IsuzuPiazza.com :: Uniting Isuzu/ Holden Piazza Enthusiasts since 2002 Forum Index -> Show room All times are GMT + 10 Hours
Page 1 of 1
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
