Contact About Us Links
FAQ - Search - Members - Groups - Register - Private Messages - Log in
Dave's Piazza Project Thread
Goto page Previous  1, 2, 3  Next
Post new topic   Reply to topic    Welcome to IsuzuPiazza.com :: Uniting Isuzu/ Holden Piazza Enthusiasts since 2002 Forum Index -> Show room
View previous topic :: View next topic
Author Message
rodavo
PostPosted: Tue Sep 04, 2007 7:23 pm    Post subject: Reply with quote
Its been a while since I last posted so heres the latest news....
Motec has been on for over 6 months now and is going great. So good to be able to tune absolutley everything about the engine. I am running a wideband air/fuel ratio meter and have done all the tuning myself. Needs to go on the dyno to do a little bit of fine tuning but being able to log in the Motec makes it alot easier to tune on the road.
I blew my VF8/Piazza turbo about 2 weeks ago. Turbo was just old and had so much shaft play that it could not be rebuilt. The centre section of the turbo was ruined. Couldnt find another VF8 quick enough so took the leap and after talking with GCG turbos have upgraded to a custom turbo. Its a Garrett GT28RS (disco potato) centre and wheels then GCG manufacture custom adapters to mate the VF8 compressor housing and Piazza turbine housing to it so the end result is a ball bearing turbo which bolts straight onto the standard piazza exhaust manifold. With a bit of fiddling with the oil feed and water lines the turbo is a direct bolt on.
Click To View Full Size Image
The result is very impressive. The turbo has totally changed the engine characteristics. It pulls so hard in the midrange now, and once I get the 3 inch dump and and exhaust on it should go well up high as well.
Havent had the car on the dyno yet, waiting for some time to finish off my exhaust and start on the intercooler project.
Dave
Back to top
View user's profile Send private message
PostPosted: Mon Sep 10, 2007 11:07 pm    Post subject: Reply with quote
Does it matter much not having the original disco potato compressor housing? Couldn't have been too hard to adapt the intake piping to it?
Back to top
rodavo
PostPosted: Tue Sep 11, 2007 12:09 pm    Post subject: Reply with quote
No, it probably wouldnt have been too hard to use the disco compressor housing, the only problem I can see is the clearance between the compressor housing and the exhaust manifold cause the VF8 goes very close to hitting it at the moment. Also would have to modify the mount for the wastegate actuator. Plus there would be an extra cost on top of what I paid to then get the housing.
GCG said that the way my turbo is now it would be rated at around or just under 300hp. Thats a bit of a guess though. The surprising thing is the piazza turbine housing is quite large even though it doesnt look it.
Back to top
PostPosted: Thu Sep 13, 2007 7:45 pm    Post subject: Reply with quote
Oh ok thought the turbo would've come with the housing already and cost more to adapt the IHI one to it.
Yeah the original turbine looks pretty big similar in size to the Skyline T3's, compressor is tiny in comparison though.. I probably could've made an adaptor myself to get the T3 mated to a standard exhaust housing rather than go to all the trouble of making a new manifold!
btw how was the all holden day?
Back to top
rodavo
PostPosted: Thu Sep 13, 2007 10:11 pm    Post subject: Reply with quote
Yeah, you can actually get the turbos without the compressor and turbine housings because you get to choose which size housings you want when you buy a new turbo.
The All Holden Day was really good, heaps of cars, over 700 they reckon. I didn't see another Piazza there and when I drove in I got a fair few looks from people and I was asked if it actually was a Holden when I was entering. Alot of people came and had a look at it, the most common comments were "Haven't seen one of these in years" or "what is it?". Pretty funny to watch people expressions as they try to get their mind around it being a Holden!!!
Back to top
rodavo
PostPosted: Thu Sep 13, 2007 10:16 pm    Post subject: Reply with quote
Also forgot to mention the other upgrade that I have done. I am now running a Procomp CDI ignition unit which gives huge spark. Worthwhile upgrade for under $300 and makes then engine run heaps smoother and start better. Should also be able to see a power improvement in the higher revs when I test it on the dyno.
Back to top
PostPosted: Sat Sep 15, 2007 5:56 pm    Post subject: Reply with quote
hehe were you running Isuzu badging to confuse them even more? I think i'd have to put all the Holden stuff back on if I went.
I thought the stock ignition gave a pretty good spark, I once started the car and was fine but went to take off and it started dying. Look under the bonnet and i'd left the lead unplugged from the coil sitting maybe 5cm away from the top of the coil and the spark was jumping the gap! But the only car i've compared it to is the Gemini with shitty points which won't fire if there's high humidity..
Back to top
PostPosted: Sun Sep 16, 2007 8:22 pm    Post subject: Reply with quote
How much did the turbo set you back???
Ive got my eye on getting one of these turbos.
-->Link<--
Is there anything that can be done about the large pics??? makes the thread hard to read.
_________________
Back to top
View user's profile Send private message Yahoo Messenger MSN Messenger
rodavo
PostPosted: Sun Sep 16, 2007 11:01 pm    Post subject: Reply with quote
That looks like a good turbo for the price. I wonder what that compressor housing and wheel is from? Other thing to watch out for on that turbo is if the wastegate port has been increased in size. If it the standard Piazza size then it might have issues with over boosting with the larger wheel and housing.
I paid $1400 for mine all up which was more than I wanted to spend but was the quickest way to get the car back on the road as it is my daily driver. Cant complain about the performance though!
As far as the pics, I am not sure how to reduce them, I think someone else on this forum reduced them last time for me? Not sure.
Back to top
PostPosted: Mon Sep 17, 2007 5:30 am    Post subject: Reply with quote
Its all good, i just slide the thing across down the bottom.
I can do what you did which is pretty much whats on eBay i think. I picked up a good RHB5 and manifold off a guy on eBay. I spied what it was, he thought diesel, i knew different. i think i paid $240. Its a mint turbo looks like its done stuff all work, manifold and dump came with it.
Ive already got a Subaru one here i bought of someone ages back. Its the subaru core with the piazza exhaust housing on it but the other two came with it as well. I didnt have the Piazza shaft to use the exhaust wheel for a better fit. I was going to put it on my good car but then i got the new turbo. With that much exhaust clearance i doubt it would have worked that good.
Now i can pull the comp wheel off the good turbo ive got and put the Suby wheel and housing on it.
How daft am i?? I only just put 2 and 2 together then. Ive had the other turbo for at least 2 months. Doh.
How do your rekon it would go on a bigger motor??? 2.3L or a 2.6L.
I definately like the the way the plumbing works on the subaru. The way you did it. The way the Piazza is done is stupid.
_________________
Back to top
PostPosted: Wed Sep 19, 2007 1:31 pm    Post subject: Reply with quote
I fixed the pics, they are thumbs now.
Bob
_________________
Back to top
speedracerles
PostPosted: Tue Mar 03, 2009 5:26 pm    Post subject: Reply with quote
Wow I know this was an old post but I wanted to know if i just buy the disco potato turbo with all the things that I would need , would I just be able to bolt it right on? I mean with some playing around with it. I know someone who is getting reed of one from one of there old projects and they would sell it to for cheap. I just need to know if it is something that I should be looking at.... Thanks prayer
_________________
Back to top
rodavo
PostPosted: Tue Mar 03, 2009 8:13 pm    Post subject: Reply with quote
The standard disco potato wont bolt straight on. GCG turbos did alot of work to adapt the IHI housings to the Garrett centre. If you gave them the disco potato and the IHI Piazza turbo they will be able to do the job but I am not sure what they would charge. Would be worth talking to them.
If you want to make an adapter plate for the exhaust manifold then you could probably use the standard Garrett but still need to play around with the oil and water piping to the turbo to make it work.
Back to top
speedracerles
PostPosted: Wed Mar 04, 2009 2:59 pm    Post subject: Reply with quote
So what turbo is the best set up for this type of job, Im just trying to bolt on something thats going to give me a little bit more power. I would like to have a bigger turbo installed but I dont know the ends and out to go about doing such a job on my own....
_________________
Back to top
PostPosted: Wed Mar 04, 2009 5:31 pm    Post subject: Reply with quote
be careful you don't end up going backwards, if teh turbo is too large you could get shocking lag and poor top end performance. Mid range should be good but you may need to upgrade the Intercooler and injectors. You can't just add more blow in isolation. Go make friends with someone who has already made all the mistakes and learn from them or throw a bucket of money at a specialsist tuning shop. I prefer reliability over a hand grenade any day.
_________________
Back to top
Display posts from previous:
Post new topic   Reply to topic    Welcome to IsuzuPiazza.com :: Uniting Isuzu/ Holden Piazza Enthusiasts since 2002 Forum Index -> Show room All times are GMT + 10 Hours
Page 2 of 3
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
