My 89 'Pulse Turbo
Madcat
Post by Madcat »
Yep I removed the sheild all together and the rattle went to the shelf with the sheild. LOL
Jim
Madcat
Post by Madcat »
wedgenut wrote:Tell you what! If you ever fancy making your rear garnish say P I A Z Z A instead of IMPULSE I would be up for a swap
Finally got a garnish plate.
Or how about this???
Jim
speedracerles
Post by speedracerles »
Im having problems with my 86 impulse turbo I think, I dont know what Oil to put in it now Im thinkin 10W/30 But I dont know ,I fill like a dummy for that... I also would like to know what is a good waste gate to put in there, blow out vaule too... I want more power. peace
New turbo would be a better idea.
Boost it too much and the EFI computer wont like it.
You just need a good oil that will last in a turbo motor.
You got an owners manual??? It has a chart in it about what oil and what climate.
Madcat
Post by Madcat »
I use 10W/30 Mobile 1 full synthetic in mine.
I see you're a member of Isuzone. Swing over there and search the old posts in the RWD section. I would suggest doing the same on this site.
Here is a common mod on the JR
http://www.isuzone.org/forums/showthread.php?t=16975
Turbo-back exhaust will also do nicely.
Jim
speedracerles
I thank you guys alot. I hope that getting info is this easy for other things about my car, LOL... So are there any ISUZU meets anywere in the states? I would love to go if so.
So what type of turbo would be a one for this car? Help me out guys... there's no greater filling then pulling up to a meet at night with something that no body has seen before, its so funny and cool at the same time. you know what I mean...Les
Madcat
Post by Madcat »
speedracerles wrote:I thank you guys alot. I hope that getting info is this easy for other things about my car, LOL... So are there any ISUZU meets anywere in the states? I would love to go if so.
There are some JI owners in your area.
An easy upgrade is swapping out the compressor housing and wheel from an '87-'88 IHI T-bird turbo.
I love the looks and attention the car gets from the local tuner scene...Its good to not drive a Honda :finga:
Jim
speedracerles
I would have to say so... I own a civic but you know how that goes. LOL thanks again. Im going to put up my cars on here very soon.. I have 2 impulse's by the way I have the 1988 impulse turbo, and the gold 1986 impulse turbo too... twice the fun LOL... I doing the swap in the red one in the next 3 weeks, Well not me but a few of my good friends... I will let you know how it goes ok peace... thanks again Speed
speedracerles
Im having some problems with my car, I have a slite knock, but not a knock more like a tick I think I
dont know what it could be from, But I looked under the car the other day and the was some oil there I
was so mad at that. Any suggestions?
Suggestion? buy something else, they all leak oil, from the front and rear crank seal is more common than not, in fact if it didn't leak i would be worried there was no oil in the engine. How do you describe a noise accurately? One mans tick is another mans terrible knock. Tappet noise is common, especially at high mileage when all the rockers and shafts get worn, try adjusting them. Good practice to check from time to time anyway. Injectors make a ticking noise when they fire, you don't hear it when driving but is noticeable at idle and some can be noisier than others. apart from a cracked piston it could be alternator, water pump, belt idlers, distributor shaft and so it goes on and on. Get a good spanner man to have a listen.
speedracerles
I also need to get my powersteering belt put back on and P/s hose reconected too... Are there lowering kits for these car too?
