I have an Isuzu Piazza,Impulse in the States,NON TURBO equiped with the G200 ENGINE.These cars seem to have some problemes with the idle speed.Mine too.
After i checked and serched the problem,i guess it comes from the Air flow sensor.
I saw on the internet that the TROOPER came with the same G200 engine in the 84`s-85`s.Does anybody know,could i find an Airflow sensor on this car(trooper).I can add that the car has auto transmission,and everytime i adjust the idling speed,after a while it goes back to under the seted value.After i adjust it in normal position,when i shift it into DRIVE it goes near to dying-the rpms drop a lot.That happens everytime-once i adjusted the idle speed much higher than normal,so when i put it into drive it arrived just at 950 rpms-but in neutral had 1500!!!
I will try to take also some pictures and post them on the forum and maybe get the problem fixed.(i am a beginner)
In general the car has no power-i checked the compresion-good.Whenever the engine is cold and i accelerate it,it chokes,drops in rpms and after that goes accelerating again.
Another sympthom of the car and maybe related,is that everytime i signal left or right,the needle from the voltmeter fluctuates with the signal and the rpms wich go up and down,up and down.
I have a MAS from an Isuzu Piazza Turbo,but when connected the engine starts but dies imediatly.
So,these are the sympthomes of my car...i hope someone can help me with some advices.
Thanks a lot!
I don`t know how u watch the pictures on this forum so i`ll put the link.
This is my car:
[/list][/code]
