Drivers window has come out of fittings.
Hi there, I have had to fit the drivers window back into the lower fittings to allow the window to operate and I have used a solution of Araldite. Any ideas on whether this will last? I have my suspicions that with heating and cooling the Araldite will probably crack, so what methods have other folks used when in this position. Thanks sbs.
Well at least you were smart enough to avoid silicone (RTV) of any kind. Never use silicone on glass attachments like this as it imparts some of its molecular make up to the glass and it can't be removed, the result is that it doesn't matter how well you clean off the silly coon what you use after that it won't stick for long.Hi there, I have had to fit the drivers window back into the lower fittings to allow the window to operate and I have used a solution of Araldite. Any ideas on whether this will last? I have my suspicions that with heating and cooling the Araldite will probably crack, so what methods have other folks used when in this position. Thanks sbs.
Araldite might last okay but the recommended product is a urethane glass adhesive. 3m do a range of products and primers, you could try supercrap but any autoglass outfit will have it and sell it to you. Best to do it right
Hi there wedgenut, thanks for the advice and I will make a note of your suggestion. Is there no end to your automotive knowledge? Thinking about it now I suppose that I could have phoned a car glass repair firm and sought advice but why be a member of this site and not use it?
You must have a ball keeping your fleet of Piazzas up and running, how do you do it? Thanks again, best wishes, sbs.
- speedracerles
Dear agony aunt "my window doesn't go down/up anymore" should I tell my girlfriend It isn't her jeans that makes her ass fat?
This is am old and trusted Piazza trait. There are two types of mechanism, one has a bowden cable drive from the motor and the other is a flexible worm drive.
The worm drive style don't often break so it is likely you have the cable style. What happens is the cable has a ferrule clamped to it that locates in a plastic clip on the window bracket. the plastic clip can easily break if the window is stuck or too tight. It usually happens on the way up when people closing the window hold the switch on too long after it has reached the top or some clown tries to force the window down from the outside in attempt to pinch your five buck stereo.
This is always assuming the window motor is working. If the above has happened you will hear it running with nothing happening. If you can't hear it then the motor isn't working either from a blown fuse, faulty relay or broken wire. You may even have a faulty switch. But two faulty switches is unlikely so if it doesn't work off either door switch it probably isn't the switch.
If you trace the fault and need parts I can probably assist. If you need to take the door card off and have not done it before flick me an email and I will give you step by step to save you some grief.
I am THE expert on these damn windows having fixed several over the years
- speedracerles
