Different Dashes?
devilishdesigner
Junior Member
Junior Member
Different Dashes?
Post by devilishdesigner »
Hi guys, I currently have an 86 hden piazza 2l turbo manual with digital dash. I would like to change over to an analogue dash and a friend from the UK has offered me an analogue cluster from a lotus tuned automatic turbo. Will all the wiring plugs and speedo cable match up and work properly?
No.
But conversion should be possible.
Try to get its plugs supplied with it.
devilishdesigner
Junior Member
Junior Member
Any ideas on the differences? I was hoping same engine = same dash wiring
A resistor is needed for the fuel gauge.
And a different connector I think, but certainly some different wiring.
I have an analog in my 86 4zc1-t Piazza.
I presume its from NZ (G200W or G200Z).
You do realise the UK analogue dash will be in Miles and not km's? Wiring plugs for analogue are two round multi pin type. The resistor for the fuel gauge will be already attached to the back unless someone has removed it. You should be able to wire it up but you will need the manual to check the pin out comparison between the digi version and the analogue, just to make it a pain the colours may not be exactly the same either, Isuzu were a pain at using whatever damn colour they had left in the skip in later years but the ozzie cars should be correct to the ozzie YB manual and it has both pin out diagrams i'm sure.
devilishdesigner
Junior Member
Junior Member
Thanks for that. The cluster has miles and km on it, but I'm quite used to driving in miles, my daily driver was built in 67!
If you go to the wreckers and scour around you will be looking for a KB rode with a sports dash in it. The speedo head looks to be the same as the one in the Analogue Piazza dash and should swap over easy enough.
I think you will have lots of fun with the wiring.
Any info you will share will be greatly appreciated, i would be looking at doing the same thing later on down the track.
Cheers, Bob.
devilishdesigner
Junior Member
Junior Member
I'll do a comparison of the 2 units when mine arrives, but unless it's a simple swap I won't go to the analogue for a good few months, until I have the car up and running properly with the digital dash.
