turbo and non turbo ecu`s
Posted: Sat Apr 12, 2008 2:49 am
I have 2 piazza`s.One non turbo wich is registered and one turbo not registered and wich hasn`t much on it.
The non turbo has an auto transmission with 4 speeds and the turbo has a manual trans with 5 speeds.Unfortunatly the turbo`s engine is nude,that means i have only the block,the exhaust manifold the flywheel...
The ideea is that i want to put the manual trans from the turbo on my non turbo.
I know it works and it bolts fine,but does the ecu has any difference?
I have all i need:the trans,the pedals,the clutches master and slave,the flywheel,i will buy a clutch kit for a turbo,but is the ecu from the auto different from the manual and if it is will it affect the performances?
I read on the forum that i have to close the circuit of the auto,to fool the ecu,if not,the engine won`t start.
The auto has an overdrive option-is that an option controlled by the ecu or the gearbox(i think is gearbox controlled).
I tried to search the forums for not questioning the old questions,but if u ,guys outhere,know more things about this kind of swap and all the thimgs i have to be carrefull with,please let me know.
We all know that piazza`s,parts and info`s for them are hard to find,but for me you are almost the only source,cause in my contry i may be the only owner,and i am verry serios...i already bought a manual from ebay,wich helps me and now i am waiting for a parts codes manual wich i also bought it from ebay.
Thanks!
Thanks!
