are you sure it is the e-brake light and not the brake system light. our models have two lights, one with the brake shoe style symbol that comes on when the parking brake or E-brake as you call it is on. There is another red warning light with a letter "P" in the centre and it comes on if you have one or more of your brake lamps inoperative every time you press the brake pedal. If it is the "P" light you probably have a lamp not working somewhere. if it is the E-Brake light the problem is almost sure to be at the switch on the lever . slide off the hatch and fuel knobs and lift off the plastic cover and remove the dime that is rolling about in there jamming the switch from time to time. WELL IT MIGHT BE!!!
No my car just has the brake light come on it says brake on the light and its red, and it happens when I drive or when I switch gears then it will go off. but it does it the whole time I drive the car. Im going to take pictures of the car today then put them up on here....
My brakes work when they wont to LOL.... I have to pump them a few time to get them to work. I just thought it might be me needing to get new brake lines and stuff like that. I dont know. all I know is when I do drive my car I have to stop alot sooner then every one else does... I just down shift alot also. So what do you think I should do then? hit me with the word...LOL
Now I have a new set of problems, I just found some major rust right by my Left front shock and you can see all the way through to the bottom. Im pissed because I know that its going to get even more bad here soon. any thing you guys think I might do about the problem, besides taking to the shop and haveing them redo the whole front end.i just want to cry....LOL
