Help
Posted: Fri Jul 01, 2005 6:57 pm
Hoping someone can help me......
My piazza had bubbles in the water and was starting to get water in the oil....so off came the head to replace the head gasket.
Head gasket seemed fine and after installing a new one and putting it all back together, the car will not idle but runs perfectly if you use the throttle to keep the engine running above idle. As soon as you get off the throttle the engine dies. I have spent so long trying to work out why, not sure if it is an electrical problem or an air leak....does anyone have any ideas. I am sure that evrything went back the way it came off, since the intake came off with the head so the wiring and hoses had to be disconnected on the intake side. I am lost for ideas.....
