Suspension Bushings
rodavo
Suspension Bushings
Post by rodavo »
I just found out my suspension bushings are worn badly on my Piazza. I went to a Holden dealer and they said that the bushings have been discontinued and are no longer made. Has anyone had to replace their upper and lower suspension bushings and if so where did you get the bushings or did you use bushings from another car, ie gemini or something else??
bugle
Post by bugle »
This is for the front?
The upper arms seem to be the same as Geminis therefore they should be the same. Lower bushes to the crossmember might be the same too, but not the radius rods coz gemini doesn't have that.
I recently did the rear end had to make the bushes which were stuffed..
