I have read a few times now of other owners still using their original stereos with no problems at all, so I am thinking that they are a pretty good unit, but my unit is being a pain. So, has anyone had to have their units serviced and if so will most established audio repair shops be able to handle the job? I want to avoid putting in a non-original unit if I can.
Thanks guys,sbs.
original stereo cassette being a pain.
- speedracerles
re :- problem with tape deck
The problem with the unit is that their is a lot of audible interference behind the music, very similar to feedback. When the tape is first started the speakers let loose with a high volume crackling sound, this settles down to the feedback type of noise. I have not tried a head cleaner yet and, who knows, maybe it could be that simple.
If it is the old original am/fm stereo with the separate cassette unit i think i have a few spares as well. Check the din plug link between the two to make sure it is in properly and that the braided earth strap from the carrier frame is going to a clean earth stud, usually attaches from the left side of the carrier to one of the two studs on the bracket on top of the tunnel. Certainly sounds like a bad earth or connection but it could be a stuffed read head.
These are bullet proof, i think every car i have seen has had one in it and they always seem to be working as good as new.
- piazzanoob
- Probationary
