Cheaper piazza parts. Post what u know R&D
Hey as most people know, piazza parts arnt cheap and hard to find.
What do u do if your starter motor or your fuel pump goes?
THis thread is about helping eachother. So if you know any parts which fit on a piazza from a diffrent car, post them.
Here are my 2 cents:
- Holden Rodeo Rear main and Timing Seals
- Holden Rodeo Fuel pump
- Ford Bosskit (Sorry forgot which ford its was.
I think it was the older model telstra or laser.
It took me forever to find one for my steering)
- Gemini gear box ( I am not 100% on that)
- Gemini Starter motor
Alot of Rodeo and Gemini parts fit on a pizza.
? Last Edit: Apr 15, 2004, 9:15pm by Chris Schumann ?
The piazza gearbox front half of the case is the same as the gemini. The rear half is the same apart from where the two holes the remote shifter attaches to. They're shifted backwards if i remember correctly.. One hole of the remote shifter will still line up. The output spline is different. The drive gear bearing retainer and clutch fork are different to suit the push hydraulic clutch setup.
Gemini upper balljoints are the same apparently..
searched high and low for a waterpump. Powermax, the most used distributor which most auto places use don't do water pumps anymore. Shuttle doesn't fit since the shaft length is longer, so you fan belt will be out. I found the best way to order other then america where you will pay 90USD in post was New Zealand.
Partsco.com had it. Part is made in new zealand by BNT. I haven't received the part but will update later.
BTW, after 3 weeks searching, rare spares auto1 had access to a genuine article and it was $319AUD.
NZ one will end up costing me roughly $180.
can you guys help
im putting the 2ltr turbo engine into my vauxhall chevette does any one know what gearboxes bolt up to the 2ltr turbo engine, most suspension and running gear from the piazza bolts over to the vauxhall,
cheers
riggi
cheers
riggi
I might have an answer here,botcolon wrote:searched high and low for a waterpump. Powermax, the most used distributor which most auto places use don't do water pumps anymore. Shuttle doesn't fit since the shaft length is longer, so you fan belt will be out. I found the best way to order other then america where you will pay 90USD in post was New Zealand.
The piazza water pump, what size are the bolts that hold the fan and pulley on???? I havent pulled my piazza apart nor looked. any one know off the top of their head???
Im putting a 1.8L motor in a shuttle that used to have a 2L motor in it. The 2L had 8mm bolts and a longer neck, the 1.8L has 6mm bolts and a shorter neck. The spacings on the holes are different as is the diameter of the center locating shaft/hub that the pulley and fan go on. The different pumps pulleys and fans have different depths/offsets to suit the shaft length, but everything ends up in the same place.
They both have fixed 4 blade fans. I think the piazza has a viscous hub, is that right???
If any one has a Piazza pump they can measure please do so. The distance between the holes and the size of the boss/shaft in the centre. The pulley off set for the belt might be handy too. Before i put the radiator in the bus tomorrow i will take some pics and measurements.
The 1.8L pump may be a straight match or with a bolt hole change a cheaper replacement.
I will have a look for the 2.3L pump, i think i used it on the 1.8L when i put it in the ute. Ive got a 2.6L pump here and its different where it goes onto the block, it goes onto a bigger hole, but has the same bolt pattern to mount it on the block.
This thread is not covering too many exacting matches, ive nutted a few things out, i will start another thread soon. this one can be for guesses and sorting stuff out. Does that sound fair enough guys???
Ive got a few pics and stuff to load off the computer once i clear some hard drive room, then i will post up what ive sorted.
- speedracerles
There ya go just add turbo
http://cgi.ebay.com/ebaymotors/NEW-ISUZ ... 0087428619
