Need this part new!
Need parts for your impulse? Look here
speedracerles
Need this part new!
Post by speedracerles »
So can anyone tell me what this might be called? and how can i go about getting a new or used one?
Came from here:
Its a piece of kit fitted to cars with water cooled turbo, It isn't fitted to all water colled turbos though. Most just have a straight water hose. This is obviously vacuum operated so I'm guesing when turbo temp gets too hot or too cold, something somewhere else in the system opens or closes to open/close this valve. Probably not needed in fact. Perhaps one of the aussies can help as they had WC turbos.
Yeah - the valve is closed when cold to prevent coolant circulation for faster turbo warm up.
Once warm, the valve opens and allows circulation.
Unless wanting to keep it standard, I reckon replace it with plain hose.
You can remove the attached air-valve - and something else... a relay?.
Users browsing this forum: No registered users and 6 guests
