Bit bored so i read up on piazza's.
from alot of reviews it seems that the piazzas handle like umm "dogs balls". This was mainly cause of the front end weight bias? so to change all that would you lower the car and make the suspension stiffer? or do you knockout a random person and strap them to your boot?
Piazza Handling
Piazzas poor handling was due to a number of things, including the fact that 61% of the weight was over the front axle. This isnt the only problem though. Most FWD cars have that amount of weight over the front yet still handle good [que Honda Type R and JT Geminis] - it comes down to suspension setup.
One thing that definately needs attention is spring rates. Part of the handling problem is weight transfer - for the moment im pinning it on the standard springs as i have a feeling they are way to soft. Im currently trying to track down aftermarket lowered springs with a stiffer spring weight which should fix things considerably.
Hrm, the Handling By Lotus or Irmscher Piazza suspension would be good....
As soon as you lower a piazza it seems to go alot better in the handling part. I am not talking about cutting springs here (you animals)
And if you still want a bid more weight in the back get a few subs and some amps.
depens on what you want the car to do as well. i mean if you want to be able to go into a corner and throw the arse end out ala drift style then they have the perfect setup for that just like a silva does. but if you want a fast track car then that is a different story but it is like anything all you need is practise and the car will do want you want it to do
Cheap handling fix
I had my Piazza lowered a few years ago due to the car being higher to one side. The only way the guy could fix was to lower it the other side. I then had better handling. Well it takes some time to get to know your limitations on this car (The great ocean road proved that !) Anyway back to subject ! I recently got my boy back on the road and heard that Nitrogen in tyres can help with ride and handling. I found that it seemed to stick to the road round corners better. I paid $6 for each tyre at Bob Jane.
Just one very important thing about that type of wheel spacers. Totally illegal in all states.Matt wrote:I currently have a set of these in my posession. They are bolt on wheel spacers to suit the 4x100mm stud pattern.
If anyone is interested in them let me know and I will get a price on coping them.
Matt
Keep in mind these appear to be pretty deep. That means the wheel nuts are barely able to locate on the original studs. Even by replacing all the original studs with a set equally longer as the additional thickness of the spacers, you place additional stresses on the wheel mounts.
It may never happen but the likelyhood of fatigue occuring and studs failing is significantly increased especially if you like to push the car hard through corners.
