Im looking at another car a clean rare 89 turbo but automatic,how hard is it to do a swap and what is needed?
Thanks Sean
5 speed Swap
5 speed Swap
And the splines are probably a different diameter (even if the shafts are the same length).
I thought the ECU might be enough of a put off, but there's flywheel & bearing, clutch assembly, gearbox; pedal box, complete clutch hydraulics & mounting; cabin boots & trim.
