Driveshaft
Skrilla
Driveshaft
Post by Skrilla »
Going to convert my auto to a 5 speed ,do they share the same driveshaft or should I grab that too?
Grab that too.
YES! Not sure for Piazza's but often it's a larger spline/yoke.
The shaft length can also vary, though shortening a shaft isn't a big deal (and has the advantage of a balance).
FYI - if you have the 1"external circlip uni joints, all yokes can be obtained.
I have 2 Piazza autos. One uses the 1" UJs (same as my old Belletts, Florians etc) whilst the other has the larger Gemini type.
I've had luck with my (non-Piazza) Isuzu changes. Fitting Gemini/Rodeo 5-speed boxes to my 1965 4-speed merely meant using a Florian tailshaft for length, and using whatever yoke (early course or later fine or larger fine or automatic (= VN Commodore?) fine spline.
Whilst Isuzu are probably the masters of interchangeability (eg, 1989 Jackaroo/Rodeo LSD banjo into my 1965 Wasp; or 1986 Piazza LSD into 1969 Florian, or Piazza & Jack/Rodeo banjos if you change the crown & pinion for the right ratio), I simply lack the experience with Piazzas and later vehicles. (Though I recently wrote of interchangeability (with mods) of Jackaroo & Piazza cruise control boxes.)
Skrilla
Post by Skrilla »
Thanks,Im just going to grab it.
