2 FRONT + 2 REAR cross drilled/slotted brake rotors
FITS FOLLOWING APPLICATION:
Isuzu Impulse 1986 - 1992
Note: Please specify the exact year, make and model when purchasing. For the 1990 - 1992 models, please specify if vehicle came with or without Lotus supension.
These rotors also include FREE zinc silver plating which will prevent the rotors from rusting on the hub and vents of the rotors. See above for the ACTUAL picture - not universal or sample photos like what most sellers use
PLEASE VERIFY THE YEAR, MAKE, AND MODEL AT END OF AUCTION FOR FASTER PROCESSING.
Cross-drilled and slotted rotors give the maximum braking for performance cars under all necessary braking conditions. Precision machined holes or slots on the rotors will allow hot gases from brake pad to escape quickly to prevent skidding or locking up. It also provided quick responds to improved faster stopping power and enhancing the look of your car. Each rotor is also zinc plated to prevent rusting and is made of the best quality metals. Cross drilled and slotted patterns are precisely CNC machined for perfect fit to OEM specs for use with OEM calipers and wheels so no other upgrades is needed.
Advantages of Cross-drilled and Slotted Rotors:
-Maximum air circulation for increased cooling
-Improved wet weather braking
-Mill balanced to prevent vibration
-Zinc Plated for protection against rusting
-Increased brake pad bite
-Cooler brakes Pad
-Promote longer rotor and pad life
http://cgi.ebay.com/ebaymotors/Isuzu-Im ... 8226QQrdZ1
