MAKE MODEL YEAR CYL FUEL PUMP NOTES
ISUZU Impulse 1983-87 4 724-388 TO 5/87-W/O TURBO
ISUZU Impulse 1983-87 4 724-388 TO 5/87-W/TURBO
REBUILT FUEL PUMP
NO CORE CHARGE
STOCK OEM REPLACEMENT
THE ELECTRIC FUEL PUMP REMANUFACTURING PROCESS
THE ARMATURE IS SURGE TESTED FOR AIR / LAYERED SHORTS AND OPENS
THE ROLLER REACE PLATE IS RENEWED WITH A HIGH CHEICAL RESISTANT, VERY LOW WEAR MATERIAL.
PRESSURE LIMITER TESTED FOR PROPER SEAL AND PRESSURE ENGAGEMENT
ALL INTERNAL "O" RINGS ARE REPLACED
ALL FINAL ASSEMBLED PUMPS ARE TESTED TO MEET OR EXCEED THE OEM STANDARDS FOR, FLOW RATE, FLOW PRESSURE, DB NOISE LEVEL OR THE PUMP.
http://cgi.ebay.com/ebaymotors/PYTHON-F ... 9587QQrdZ1
