Rims were only 16in, which was considered pretty big back then. Woo hoo! Before selling it I installed a two-way water/methylated spirits injection system which squirted a fine mist before the turbo, and another mist over the factory intercooler, installed a custom oil catch can, and installed custom bonnet vents, which can be seen in one of the photos. Other specs were as follows:
050" thou overbore cylinders with Cosworth pistons
Fully balanced bottom end
Recalibrated ECU to 15PSI boost (not sure what was done)
Full 3 inch mandrel bent exhaust system with a 4 inch 'hot dog' resonator and a 5inch tip!
Cold air induction system with Ram Pod
Commodore VL turbo fuel pump
Malpesi rising rate fuel pressure regulator
Front suspension- Extra heavy duty lowered EA Ford Falcon springs (((Lovells cut to desired ride height)
Rear suspension- Commodore VL turbo wagon rear springs (Lovells)
Koni adjustable shocks all round
Whiteline custom 27mm solid front sway bar. Nolathane bushes.
Custom K-mac 16mm solid rear sway bar. Nolathane bushes.
Interior- Japanese spec analogue dash cluster
Momo Cavalano III steering wheel
In cabin adjustable boost dial
VDO boost gauge
Momo gear knob on a shortened lever
120w Sony speakers with crossover tweeters
The front seat rail was modified to enable my 6'5" frame to fit nicely. For this to happen the height adjustable mechanism was removed, and the mounting brackets under the seat were lopped off and repositioned to increase leg room. The conversion was really easy, but the effect was amazing. I now had massive leg and head room, but because my bum was only centimetres off the floor I swear it was like driving in a go kart, not to mention the advantage of a lower centre of gravity.
Car was originally registered in Vic. I then registered it ACT, and finally in NSW.
Anyway I hope the car is still worthy of inclusion on this illustrious forum:
