Via e-mail:
"Hi Daniel
The 95mm gaskets are coming in the next 2 to 3 weeks , i just sold the last one the other day
The cam gears are done when i receive the old gears from customers , they are real slack at doing that by the way
Flywheel are available , I weighed the one i have done and it weighs 6.3 kgs
Cheers Lee"
That should tell you about the cam gears. lol.
As far as the flywheel goes. The factory 4Z flywheels all weigh in around 10kg or 22-23lbs, give or take. The chromoly version he made is 6.3kg, or 13.9lbs for those of us on the standard system. IMHO, that is the perfect weight for a lightweight flywheel for a vehicle being used as a road/track machine.
As far as the custom pulley goes, I am having one made by Paeco.
http://www.paeco.com/Aluminum%20Pullies.htm
This is the same company, I believe, that Isuzuperformance used to have theirs made. It is also the same company that produced Soren's crank pulley. Shown below (this is a 4zc1-T pulley).
Soren wasn't very specific, but he said that pulley was around a 30% under drive. I was going to request around a 20-25% for mine. He also said that the new pulley weighed around 2lbs, which is a lot lighter than stock. Not only is this a huge decrease in mass, but the reduced diameter also decreases moment of inertia thanks to the smaller diameter and reduction in mass from the outer edge where most of the weight is. Combine the two together and this will make a big difference on reducing parasitic loss.
Cost will be around $380 USD, but I will know for sure when I get a call back from them. I have to go retrieve my radiator to be sent off to Ron Davis for my custom one as well as my stock crank pulley to ship off.
If you are looking to buy one in the next few weeks I could request two be built. I was considering getting one done that just ran the AC and alternator (two grooves) since I do not plan on running PS, but I may just get all three. You could have yours done however you would like. Just let me know if you would like to get in on it and we can work out details.
