Does gemini springs fit piazza???
I want to get my piazza a little more down to the ground, but its kinda hard to find lower springs for it... But I have found some Gemini lower-springs. DOES GEMINI SPRINGS FIT THE PIAZZA???Thanks
i am not 100% but I am pretty sure they do.. That probably doesnt help.
^ I've done it the other way around, and yes they certainly do, I found the piazza springs a little softer than gemini ones, although a tad lower, the springs I had were from a g200z auto piazza..
Cheers,chris
Cheers,chris
Oil leak? What oil leak? That puddle under the car is just sweat from all that horsepower....
Thanks!!! But I got another question. Does the complete coil from gemini fit piazza???????? I'm thinking about the RWD geminis(years 75-85?)
Thanks!
Thanks!
Should do, as thats what I put the piazza springs into, TF Gemini wagon... Same dimensions in piazza springs & gemini's - piazza's were a little softer in the particular one I had
Also you're talking about lowering it, I chopped 2 coils from the front springs - still fully captive, lowered it so enough so the tire is still below the top of the guard (not tucked up underneath it) , soft enough to not have a terrible ride, and hard enough to get a positive handling change..
I ended up putting piazza front shocks into the rear (2" shorter - so less droop) and fiat 131 front shocks in the front (2" shorter again) To start with I was using cut piazza rear springs in the rear but it wasnt quite right, ended up using king spring superlows..
You're from norway, so I suspect ebay will be the best option, Vauxhall chevettes also share the same floorpan etc, and these parts are interchangable, Opel Kadett in germany, Chevy Chevette in the America's..
To note, all shocks Ive had for Piazza, Chevette and Gemini have all been the same on each axle, ie fronts from chevette are the same as fronts from a piazza & gemini
Spring rate seem to vary dependant on maker..
Ok, Mabye I can find some for manta, ascona or kadett then. Thanks!!!
Just to make shure I buy the right stuff; Kadett C springs will fit piazza? I have found Cobra 40/40 for the kad C...
