So I'll put up what he should have.
Well I'll be...good pick up there Ghost. I thought you were talking the rear garnish. That is so wrong. Although I do wonder what he did to rear suspension to cost the owner $2K.Ghost wrote:Nope, it says holden http://www.flickr.com/photos/rvp-cw/631 ... /lightbox/
Holden didn't develop anything to do with the engine management, the mechanical timed distributor & fuel only ECU was on JDM 4ZC1-T models from the start right through to 89. We seemed to get the equivalent of a JDM Piazza XE just with a 5 link rear end and hard plastic bumpers.IZU069 wrote:It's a 1984 with G200Z engine and I-TEC EFI...
Lucky bastard - that means the full electronic timing and fixed optic dizzy like our 1989 onward 4ZE1 Jackaroo & Rodeos - just like the DOHCs from 1980.
[ Techno-Political stuff: If you want to read the reason Holden went from full electronic ignition back to mechanical, be sure to read BellettNet's differential. Please note how Holden did not want to find the new timing and fuel parameters (recurve the timing etc) for the 4ZC1-t engine, so they built a mechanical distributer and used a Bosch EFI instead - no doubt using the same ignition and fuel curves as were used for the G200Z engine.
