Seriously, you make it sound so easy. Maybe I should keep an eye out for pristine slushbox versions.
Scissor lift 'Lambo' doors
- Bad_Asso
- wedgenut
Fark me, not only do you need a manual, at 195cm you need a sunroof as well
And at 120kg to go with that vertical advantage let me call you sir your hugeness.
Honestly it isn't hard, easier than any front wheel drive crap. The Piazza was made in the days when all body shells were made the same to suit either non turbo or turbo and auto or manual. The normal approach is to buy a nice auto and a rust bucket manual. Hey presto you have all the bits you need. You might even gat a decent clutch kit out of the donor as well and it will be a cheap conversion.
If you do decide to do do a conversion make a note to talk to me as there is one little sneaky thing you need to know about the pedal box change that I won't go into now.
Good luck with the hunt
- Bad_Asso
Thanks for the heads up re the conversion. Yeah my height is usually a hindrance to a lot of cars I get into, and the Piazza was no different. but because I loved the car so much I made sure it was going to damn well fit me. I got creative and took the seat-lift mechanism out, which allowed the seat to pretty much sit on the floor. Next thing I did was to re-locate the brackets that bolted the seat to the floor, so that it sat back further about 100mm. And presto. Car fit me like a glove, and my centre of gravity was lower as a result.
- vinnie55
I'm glad you said that wedgenut, because I was under the impression it was a really full on task.
That said I'm no mechanic and didn't understand half of that.
But suddenly one of the Piazza's I herd about someone else buying I have just now been told didn't get sold, It's white, supposedly fairly tidy and above all IN ADELAIDE.
But if I remember correctly it's an auto. If that's the case I may even be able to buy it now.
I think rodeo bob also has the parts to do a conversion, so there is at least one lot on the west island:P
- Bad_Asso
- Power Moderator
- Bad_Asso
- vinnie55
- wedgenut
- vinnie55
- wedgenut
Oh Shit a Renault Fuego!!!! Now isn't that the car they say was designed for french tarts? I bet you cut a dashing figure in your fishnets, not that I am remotely interested of course.
PS what is your hourly rate? I'm asking for a friend...honest!
Don't mind me i'm just a sick person.
- Power Moderator
- Bad_Asso
Off topic a bit but I thought I should show a rear view pic of that same Lambo-doored red Piazza from Japan. How ugly is that??? Shocker if you ask me.
- Power Moderator
Yep - fugly.
I like them on the old Mazdas, but not on the Piazza compared to their usual.
But I once thought the same with later Belletts (the 1800s including the GT & GT-Rs) with their "plastic" grill trim and some of their square or round tail lights, but they grew on me... and I kinda like them now.
Okay - maybe not the tail lights, but if their fugly fronts are now IMO acceptable - maybe even attractive.... maybe - then I won't rule out that those Piazza tails might one day be, er, acceptable....
(Never say never. And never say ugly - whether fugly or not!)
- Bad_Asso
Users browsing this forum: No registered users and 48 guests
