http://www.isuzupiazza.com/forum/viewto ... 2167#12167
just ask if anything is unclear, but even an auto electrician should be able to follow this
Sorry Bugle you lost me when you said 4th gear doesn't have any gears. Gearboxes aren't my thing. All I'm told, and was physically shown, was that the 4th gear was badly worn as was the input shaft, and oh yes I forgot to mention, the main (output) shaft. I assume the counter shaft is the external looking shaft running along the top of the picture? No they're fine. No scuff marks and excessive wear on any of them, especially the one attached to cog that drives 4th gear.Bugle wrote:Sure the gear that it runs onto on the counter shaft hasn't worn aswell? It's not 4th gear, it's the main drive gear. 4th gear doesn't have any gears at all, it locks the input shaft to the output shaft with the synchro on the right of the pic. That gear would be the first to wear out because it only gets a rest when you're in 4th.
