Just with A/C, LSD, 4Wdiscs, modernized suspension, velour trim...oh, and EFI power.
Sorry to hijack the thread. Maybe just get a whiteline swaybar and whiteline bushes?
Why the HiLux???? To much hassles. Got the stud pattern to worry about and they arent as strong as the BW diff.GeminiCoupe wrote: Im leaning towards a HR with a HiLux rear end, VT discs, rack and pinion front end [i forget which car you can use to donate the rack, theres an easy conversion for it], and an EcoTech V6. If i remember correctly theres a conversion kit do it it all too. Something like this would be nice...
Yeah i know. I was thinking of making something up. Ive got some N13 4x100 front hubs here. Just make up something that runs off a washing machine motor. Dont have to spin that fast if your taking it off slow and steady.Bugle wrote:That'd be a huge lathe to be able to hold a 15 inch wheel!
It doesn't heat up at all if you keep the coolant flow high, RPM high and feed slow. Freezing goes right to the core and even after machining it is cold and hard in the middle. I do the OD first leaving the cold core to keep it stable. After turning it is still cold enough to core drill undersize. I then re freeze it before finishing the bore. Sure it is a bit of a hassle but it is only time. The last set I got made were 38 ID x 52 OD x 50 long. I made and supplied the mould and they cost me $16.00 each for a quantity of ten. Too expensive on a per each basis, if you only want a couple it would cost about the same as buying ten so i just make what I need for ones and twos but I'm glad i don't have to pay me for my time! LOLWedgenut the stuff melts so fast with a tool up against it I wouldnt have thought that freezing it would last too long once you get started.
Users browsing this forum: No registered users and 22 guests
