what boost do piazza run stock
- Learner
hi just asking what piazzas run stock
any in fo on this would be good all so does any one know at what pressher the bost reless valve on intake opens
Hey mate, please search forum first b4 asking questions wich already have been answerd.. Also I believe this information is available on the main website.
7 PSI if you must know..
- Learner
thanks heaps and i did have a good look but there was know clear answers out there. Also does any one know what psi the emergency over boost realese valve opens on intake <not the one on turbo>Chris wrote:Hey mate, please search forum first b4 asking questions wich already have been answerd.. Also I believe this information is available on the main website.
- Learner
The thread for the overboost valve is 1" BSP and they open standard at around 10psi. However and here is the sneaky bit. Once they open they can continue to bleed off until the pressure drops back to about 7psi. Don't think its meant to be like that but age and gunk probably prevent a fast close.
- Learner
The reason for using a pipe thread is sound, it is self sealing without gaskets and as it is a BSPT and not BSPP it releases easily for removal which is always a good idea when screwing into alloy.1" bsp actual diameter is 32-34mm? What a silly way to do that...
I now feel compelled to show i did learn something during my apprentice years.
Tubes (usually thin wall) are measured on the outside diameter, pipes however are measure as a nominal bore size. In other words 1" bore pipe can be larger or smaller than 1" depending on wall thickness as the outside diameter can't change to comply with manufactured fittings like tees, sockets, flanges etc. When Mr Screwit Ltd decided it would be a good idea to join pipes and fittings with threading as opposed to welding he had to invent a thread that was fine pitch for effective pressure sealing. The thread of course isn't 1" at all it is a thread that is cut on the outside of a 1" pipe. Universally it has become a " 1" PIPE - thread " and not a 1" THREAD - pipe" This applies to all sizes and is universal throughout the world, even in European and Asian countries. EXCEPT the USA where they speak funny and invented their own thread, the criteria for sizing is still the same but they use NPT which is a coarser version of BSP and the twain don't mix.
All of this applies to all sizes of pipe from 1/2" up to 6". It is unusual to find threaded pipe larger than 6" To further confuse the issue they derived two versions of BSP, parallel and taper forms. Tapers for standard fittings and parallel for running threads such as used on screwed tube and tank fittings sealed with backing nuts and sealing washers where a taper would be a pain the scrotum.
By the way there is no such thing as metric pipe, sure all the pipes and fittings are now being sold in metric designations such as 15nb, 25nb, 32nb, 40nb etc. etc, but it is a soft conversion as no physical change has taken place.
Here endeth the lesson...not that anyone is still awake
